Hello Team,
I am trying to intercept call between two users and apply AI/ML processing for the live audio stream. I found out that mod_audio_fork module should be used for that. I installed this module but when I load this module using "load mod_audio_fork" command then it returns as "-ERR [module load file routine returned an error]". when i check logs related to mod_audio_fork module then there are no logs found.
any suggestions as where am I doing wrong?
