Important Release Notice
This is an important release containing critical security fixes and stability improvements, alongside the new reloadcert API for hot TLS certificate reloads without disconnects across mod_sofia and mod_verto, and SIP 603+ detection and passthrough control. We strongly encourage all users to upgrade to v1.11.1 as soon as possible.
Release Notes - FreeSWITCH - Version 1.11.1
Enhancements
- [GHA] Update FFmpeg and libpq in macos.yml.
- [mod_commands, mod_verto] Add new
reloadcert API and allow mod_verto to reload TLS certificates on the fly without disconnecting active sessions. - [mod_sofia] Add SIP 603+ detection and passthrough control.
- [mod_sofia] Capture SIP Reason header on INVITE failure.
- [mod_sofia] Reload TLS certificates on the fly without disconnects using the
reloadcert API.
Bug Fixes
- [Build-System] Update libks requirements to v2.0.11.
- [Build] Cap cJSON parser nesting depth to prevent stack overflow.
- [Core, Modules] Fix various dead assignments.
- [Core] Fix segment count validation in
clean_uri() and add unit tests. - [Core] Fix use-after-free in session thread pool worker.
- [Core] Use
switch_stun_ipv6_t for STUN IPv6 write paths. - [libesl] Fix build of tests.
- [libesl] Validate
Content-Length in esl_recv_event. - [mod_commands] Fix
reloadacl description. - [mod_erlang_event] Fix correctness, OTP compatibility, and memory issues.
- [mod_sofia] Fix handling of
sip-options-respond-503-on-busy profile parameter. - [mod_sofia] Fix use-after-free in dispatch event thread.
- [mod_verto] Defer userauth state writes until after password validation.
- [mod_verto] Fix heap overflow in HTTP POST body read.
- [mod_verto] Gate session ID binding on authentication and block cross-identity eviction.
Key Highlights
- Hot TLS Certificate Reloading: Certificates can now be reloaded without disconnecting active SIP or Verto sessions.
- SIP Failure Visibility: Improved handling and reporting of SIP 603+ responses, including Reason header capture.
- Security Improvements: Fixes for use-after-free vulnerabilities, heap overflow conditions, parser stack exhaustion, and authentication hardening.
- Operational Stability: Multiple fixes across core, ESL, Sofia, Erlang, and Verto subsystems.
Installation Guides
