🔹Project Level Settings at Your Command!
Within each project you can now turn on or off the following settings, giving you more control when you have multiple projects running.
Protect media URLs for fax, recording, and messaging — when enabled, direct URLs must be authenticated to access.
Force HTTPS requests — for optional added security, prevent HTTP URLs from being saved for usage. When enabled, HTTP URLs will be converted automatically to HTTPS URLs.
Under the "Subscriber" sub-tab (within My Resources), guest tokens specific to temporary subscriber access will no longer be visible. These guest tokens will also not show within the API. Learn More about Guest Tokens
🔹Want to experiment with our APIs?
Download the collections, change the authentication variables to their own, and begin using our APIs right away with no downtime or setup time. The SignalWire Postman/Bruno API collections have been updated to include:
Fabric APIs
CXML Start/Update Stream
Datasphere Document/Chunk Endpoints
Relay Recording Endpoints
Check out the Github
